File Monitor Trigger Changed?
Freddyc
Post by Freddyc »
Has the behavior of this trigger changed with thr latest version 2.1?
It seems that if a new file with the same name as a prior one is moved to the watched folder the trigger does not fire. The prior version fired the trigger.
Is this by design now?
The behavior of "File monitor" trigger has not change. We fixed some bugs only.
Freddyc
Post by Freddyc »
If the behavior did not change then you may wish to re-test the code as I'm sure it now has new bugs.
Just a suggestion, no need to reply.
Thank you, we'll test this trigger again.
