Count files only
KeesB
Count files only
Post by KeesB »
I need to just count files in the current directory. Is there an argument to FilesCount so it doesn't count files in sub folders?
Thanks,
Kees
Count files only
You are correct, {FileCount()} variable counts the amount of files in specified folder and all subfolders.
In order to count files in specified folder only use the File Loop:
Set variable num to 0
File Loop //without subfolders
   Increment num
End Loop
Probably we need to add corresponding system functions. I wrote this into our ToDo list.
Re: Count files only
Bumping up an old topic, because I still face this "problem" today ;) Ofcourse the workaround works, but it will be great if that can be fixed into a system variable.
