Monitor folder
dbortunk
Monitor folder
Post by dbortunk »
How would you create a task to monitor if a folder exists and if it does not exist send an email and create the folder and continue monitoring if it exists?
Monitor folder
IMHO, it's better to make two tasks.
First task monitors the folder c:\MyFolder (see "file monitor" triggering event)
Second task checks the existence of the folder and creates if it doesn't exist.
If {FolderExists(c:\MyFolder)}=false then
   create folder "c:\MyFolder"
end if
Second task may be triggered by Cyclic event. (suppose, each 15 sec)
dbortunk
Monitor folder
Post by dbortunk »
I don't see how you setup the file monitor to watch for a folder existing or not.
Monitor folder
See my previous post. You don't need file monitor to check existence of the folder.
Also see the task below:
CatID=INTEGER|1380072790
ExternalName=STRING|"Task785"
ID=INTEGER|101531131
Name=STRING|"Check the folder existence"
operator=STRING|"1"
value1=STRING|"{FolderExists(c:\testfolder)}"
Name=STRING|"Create Folder (c:\testfolder)"
newfolder=STRING|"c:\testfolder"
id=STRING|"C1TFCGHI"
interval=STRING|"15"
