Delete Empty Folders
dbortunk
Post by dbortunk »
Is there a way to delete empty folders with Robotask? Meaning in a directory tree only delete the folders that are empty
Look at the "Remove folder" action.
Also you may check folder size before deleting, like this:
if {FolderSize(c:\myfolder\subfolder)}=0 then
   Remove folder c:\myfolder\subfolder
end if
dbortunk
Post by dbortunk »
Yes but i am asking if it can delete all empty folders in a directory tree. There may be 5 there may be 500. The code you pasted will delete a specific folder
Use this algorithm in the "File loop" action.
Like this:
File loop //by folders
   if {FolderSize({CurrentFolder})}=0 then
      Remove folder {CurrentFolder}
   end if
end loop
dbortunk
Post by dbortunk »
It stops when it finds a folder with a file in it. I would assume that it would skip that folder and move on to the next folder because of the loop but that is not happening.
There is {FilesCount()} variable. It counts the amount of files in the folder and subfolders.
   if {FilesCount({CurrentFolder})}=0 then
   end if
end loop
