Hi there!
RoboTask has a feature to start programs with "General/Run program/Open document" but there is no feature to kill programs/tasks.
It's possible to end programs with the "Send Keystrokes" feature (Alt + F4) but unfortunately this will make almost program windows smaller (it's the same effect if you click on the window button left of the close button).
Perhaps it could be possible to add this Feature in future versions?!
Best regards,
Zocko
Feature request: Kill program/task
AlexeySurkis
- Contact:
We can add the "Kill Process" action, but the only reason why we still did not it is "killing" a process may cause some data loss. Try to use the Window Command->Close action instead.
hmmm , Kill proces missing 4 me 2...
many apps going to try on close...
Thanx
ps: pls add as expert features...
Thanx
