Number in Excel cell-variable
carroll
Post by carroll »
How do I assign a number in an Excel cell to a variable?  I understand how to use "get text" when the cell has text content....but ???? if the content is a number?
Carroll
Migg
Post by Migg »
Maybe you can copy the number into the clipboard and then assign it to the variable.
carroll
Post by carroll »
Migg,
Thanks for the help.  I was copying to the clipboard, but was hung-up on using "get text".  Somehow your answer made me think to use the "set variable" and assign the clipboard content to the variable.
thanks
carroll
Post by carroll »
Migg,
oops...that doesn't work - assigning the clipboard content to a variable only works for text.
I must be missing something....I would think it would be easy to assign the numeric value in an excel cell to a variable - right ???  Carroll
Migg
Post by Migg »
You can easily assign numbers to variables.The answer from Oleg to my question was:
Oleg wrote:Just set 0 or 1 or 2, etc
You can't declare the typed variables. You must set the numeric value only
carroll
Post by carroll »
Oleg,  I don't want to type in the value 1,2, etc.  I want Robotask to read the number = such as 23.45 - in the cell into the variable and then continue with the task.  I tried to set the variable to {clipboardcontent}, but that doesn't work for my situation because when I use "copy" in subsequent actions, the variable changes.
Thanks
Excel addes end-of-line symbols to content, when you try to get cell value into clipboard.
So you have to remove EOL symbols before using (see STR Trim)
