Robotask "If then" with boolean selection
Migg
Post by Migg »
Hi there,I want to use RT to start some additional programms, but not with the start of Windows. I want to create a boolean variable, but I don't know how to do it.I use RT3.1 from the german "PC Praxis".Maybe someone can help me here.thank you
All variables in RoboTask are strings
Just set True or False to your variable and you can use it in "If..Then" condition with "as boolean" option
Also you can use Yes/No pair
Migg
Post by Migg »
Must I take a new variable?In some trys I set True to the variable but RT brings an error back.
Oleg wrote:All variables in RoboTask are strings
What error?
"True" or "False" is a same string as another srtings.
also publish here your task. I want to look it.
Migg
Post by Migg »
Oleg wrote:What error?
This is my task (RT says:E: 14.04.2009 16:09:16: Value "Test1" is not compatible with boolean expression):;*****************************;* RoboTask Task file         ;* Do not edit in text editor!;***************************** [Root]ActionAfterRun=INTEGER|0Actions=FOLDERAutomat=INTEGER|-1CatID=INTEGER|1320534252ContinueOnError=INTEGER|0ExternalName=STRING|"Task19"Hide=INTEGER|0ID=INTEGER|812578977Name=STRING|"Create variable ""TEST1"" with value """"..."Priority=INTEGER|3RunOnClose=INTEGER|0RunOnStartup=INTEGER|0ToLog=INTEGER|3WriteGeneralLog=INTEGER|0[Actions]Action1=FOLDERAction2=FOLDERAction3=FOLDERAction4=FOLDERAction5=FOLDERAction6=FOLDER[Actions\Action1]ActionID=STRING|"A_DIALOG_QUESTION"Enabled=INTEGER|-1Name=STRING|"Question Dialog"Params=FOLDER[Actions\Action1\Params]abortif=STRING|"0"action=STRING|"1"autotime=STRING|"0"buttons=STRING|"1"message=STRING|"""Do you want to continue?"""time=STRING|"60"variable=STRING|"TEST1"[Actions\Action2]ActionID=STRING|"A_FLOW_IF"Enabled=INTEGER|-1Name=STRING|"If Then"Params=FOLDER[Actions\Action2\Params]case=STRING|"1"operator=STRING|"0"type=STRING|"3"value1=STRING|"Test1"value2=STRING|"""True"""[Actions\Action3]ActionID=STRING|"A_DIALOG_MESSAGE"Enabled=INTEGER|-1Name=STRING|"Show ""{TEST1}"""Params=FOLDER[Actions\Action3\Params]icon=STRING|"1"msg0=STRING|"{TEST1}"msgcount=STRING|"1"playsound=STRING|"0"showmessage=STRING|"1"[Actions\Action4]ActionID=STRING|"A_FLOW_ELSE"Enabled=INTEGER|-1Name=STRING|"Else"[Actions\Action5]ActionID=STRING|"A_DIALOG_MESSAGE"Enabled=INTEGER|-1Name=STRING|"Show ""Es wurde Nein gewählt"""Params=FOLDER[Actions\Action5\Params]icon=STRING|"1"msg0=STRING|"Es wurde Nein gewählt"msg2=STRING|"{Test1}"msgcount=STRING|"3"playsound=STRING|"0"showmessage=STRING|"1"[Actions\Action6]ActionID=STRING|"A_FLOW_ENDIF"Enabled=INTEGER|-1Name=STRING|"End If"
Use the string {Test1} instead of Test1
You may use any expression with (or without) variables. Therefore you have to write all variable names between {}. Otherwise RoboTask use this string "as is". The string "Test1" is not a boolean expression.
Migg
Post by Migg »
Outsch Now it works, thank you.Thanks also for your fast replies.
Oleg wrote:Use the string {Test1} instead of Test1
Also you may to use integer values:
0 = False
any other values = True
This is undocumented but this is working
Migg
Post by Migg »
Now I have the next problem:How can I declare number-values?Must I say (number) or <number>?
Oleg wrote:Also you may to use integer values:
0 = False
Just set 0 or 1 or 2, etc
You can't declare the typed variables. You must set the numeric value only
