Hex Code conditional
Astrael
Post by Astrael »
There ought to be an IF function which would allow the program to check if a certain pixel on the screen matches or doesn't match a particular color hex code.  This would make it a lot easier for the script to determine what was going on without manual input, and make Robotask as a whole a lot more functional.For easier use, add a small Hex code checker with which you could provide it with a Hex code with the standard click and drag style selection common amongst such programs.This would be reasonably easy to add, and make robotask far more powerful.Thanks.
Thank you for your suggestion. I've added this into our ToDo list
