STR Trim Zero Lead Symbols
simoneranucci
Post by simoneranucci »
How to trim ZERO LEAD SYMBOLS in a string?
Thanks!!!
What are "ZERO LEAD SYMBOLS"? Symbol "0"?
simoneranucci
Yes, sorry...
Hm-m... Probably we need to add custom symbols into "STR Trim" action.
Now you can do this like in the example below:
CatID=INTEGER|1939387200
ExternalName=STRING|"Task128"
ID=INTEGER|614445171
LocalVariables=STRING|"TEST,F"
Name=STRING|"Suppress lead symbols"
Name=STRING|"Set variable ""TEST"" with value ""00000123456"""
varname=STRING|"TEST"
varvalue=STRING|"00000123456"
Name=STRING|"Show ""Variable TEST contains this: {Test}"""
msg0=STRING|"Variable TEST contains this: {Test}"
msg1=STRING|"Now we remove lead ""0"" symbols"
msgcount=STRING|"2"
Name=STRING|"STR Extract"
amount=STRING|"1"
from=STRING|"1"
source=STRING|"{test}"
variable=STRING|"F"
Name=STRING|"While loop"
value1=STRING|"{F}"
value2=STRING|"0"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"1"
from=STRING|"1"
source=STRING|"{TEST}"
variable=STRING|"test"
amount=STRING|"1"
from=STRING|"1"
variable=STRING|"F"
simoneranucci
Ok, I understood how it works...
However in future version a selectable character trim would be great!
