Get file name, search string and rename
simoneranucci
Post by simoneranucci »
I have to monitor folders that contain PDF files named 12345678901-1.PDF, 12345678902-1.PDF and so on...
Then I have a recordset that contains PDF name in a certain position and an ID name in another position.
Let's say:
12345678901-1ABCDEFGHILMNOPQRSTUVZ
12345678902-1ZVUTSRQPONMLIHGFEDCBA
I have to process them getting the filename of PDF, search it in recordset and rename it with its relative ID. If I can't find the PDF name in recordset I have to move PDF in a specified folder.
It would be useful if I could search PDF name in multiple possible recorsets files...
Probably I haven't understood something...
What are "recordsets files"? Is this a some database?
You have files:
12345678901-1.PDF
12345678902-1.PDF
etc.
You have database where ID of the file looks so:
I understood so, you want to rename file
12345678901-1.PDF
to
12345678901-1ABCDEFGHILMNOPQRSTUVZ.PDF
Is this correct?
If you can't find corresponding ID in database you want to move the file into some folder
If I understood you incorrectly describe your problem in more detail, please.
simoneranucci
I want to rename file 12345678901-1.PDF to ABCDEFGHILMNOPQRSTUVZ.PDF and I have to find 12345678901-1 key in more than one TXT file.
Thank you!
...and I have to find 12345678901-1 key in more than one TXT file
What will be the result filename, if the key exists in a few text files?
What format of these TXT files?
Only such strings:
12345678902-1ZVUTSRQPONMLIHGFEDCBA ?
simoneranucci
The key should exist only in one file.
The format of text file is a 400bytes record thah has fixed position for 12345678901-1 and ABCDEFGHILMNOPQRSTUVZ fields.
Let's say 12345678901-1 begins at 200 (13 digits) and ABCDEFGHILMNOPQRSTUVZ begins at 300 (21 digits).
I hope, that TXT files are in one folder.
If so, I'll try to write an example later.
simoneranucci
Yes!!!
simoneranucci
No reply?
See the example below.
It searches PDF files in c:\incoming
TXT files in c:\txt
and moves the files if not found into c:\dest
CatID=INTEGER|1380072790
ExternalName=STRING|"Task221"
ID=INTEGER|1582561618
 LocalVariables=STRING|"C_FILE,old_filename,FOUND,C_TXT,C_LIN E,New_Name,MASK"
Name=STRING|"Search and rename"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Name=STRING|"File Loop"
date1=STRING|"20090317"
date2=STRING|"20090317"
destvar=STRING|"C_FILE"
file0=STRING|"C:\incoming\*.pdf"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Rename File"
file0=STRING|"{c_file}"
mask=STRING|"{New_Name}.*"
subdirs=STRING|"0"
Name=STRING|"//If found break the loop"
comment=STRING|"If found break the loop"
Name=STRING|"Break"
[Actions\Action14]
[Actions\Action15]
[Actions\Action15\Params]
value1=STRING|"{found}"
[Actions\Action16]
[Actions\Action16\Params]
[Actions\Action17]
Name=STRING|"Break"
[Actions\Action18]
[Actions\Action19]
Name=STRING|"Set variable ""OLD_FILENAME"" with value ""{ExtractFileNameNoExt({c_file})}"""
varname=STRING|"OLD_FILENAME"
varvalue=STRING|"{ExtractFileNameNoExt({c_file})}"
[Actions\Action20]
Name=STRING|"Show ""{found}"""
[Actions\Action20\Params]
msg0=STRING|"{found}"
msg1=STRING|"{c_file}"
msg2=STRING|"{new_name}"
msgcount=STRING|"3"
[Actions\Action21]
[Actions\Action21\Params]
operator=STRING|"1"
[Actions\Action22]
Name=STRING|"//Move file if not found"
[Actions\Action22\Params]
comment=STRING|"Move file if not found"
[Actions\Action23]
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
[Actions\Action23\Params]
destdir=STRING|"c:\dest"
f_count=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
subdir=STRING|"0"
[Actions\Action24]
[Actions\Action25]
Name=STRING|"Set variable ""FOUND"" with value ""false"""
varname=STRING|"FOUND"
varvalue=STRING|"false"
destvar=STRING|"C_TXT"
file0=STRING|"C:\txt\*.txt"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
file=STRING|"{c_txt}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"STR Extract"
amount=STRING|"13"
from=STRING|"200"
source=STRING|"{c_line}"
variable=STRING|"mask"
amount=STRING|"21"
from=STRING|"300"
variable=STRING|"New_Name"
value1=STRING|"{mask}"
value2=STRING|"{old_filename}"
Name=STRING|"Set variable ""FOUND"" with value ""True"""
varvalue=STRING|"True"
simoneranucci
Can you attache the file?
