Enable boxes
carroll
Enable boxes
Post by carroll »
How do I check or uncheck multiple enable boxes.  I takes too much time to check or uncheck the boxex one at a time
Thanks  Carroll
Enable boxes
When the checkbox is selected you may change its state by pressing the spacebar.
So you may send approx such key sequence:
" {TAB} {TAB} {TAB} " etc.
(space beween TAB keys.)
Space changes the state of the checkbox and the TAB-key selects the next input element
