Send keystrokes @
Svend
Send keystrokes @
Post by Svend »
Hi.How to send keystrokes @^(064) wont work, please helpKind regards.Svend
Send keystrokes @
Just put the @ symbol into string
Also you may use Shift-2 -> +(2)
Svend
Send keystrokes @
Post by Svend »
Put the @ symbol into string, wont work.Im using a danish keyboard, @ is (Alt Gr+2)Svend
Svend
Send keystrokes @
Post by Svend »
After install of the US keyboard layout.;*****************************;* RoboTask Task file         ;* Do not edit in text editor!;***************************** [Root]ActionAfterRun=INTEGER|0Actions=FOLDERAutomat=INTEGER|-1CatID=INTEGER|1981091247ContinueOnError=INTEGER|0ExternalName=STRING|"Task8"Hide=INTEGER|0ID=INTEGER|1014407933Name=STRING|"E-mail"Priority=INTEGER|3RunOnClose=INTEGER|0RunOnStartup=INTEGER|0ToLog=INTEGER|0WriteGeneralLog=INTEGER|0[Actions]Action1=FOLDERAction2=FOLDERAction3=FOLDERAction4=FOLDERAction5=FOLDERAction6=FOLDERAction7=FOLDER[Actions\Action1]ActionID=STRING|"A_GENERAL_SENDKEYS"Enabled=INTEGER|-1Name=STRING|"Send keys to active window"Params=FOLDER[Actions\Action1\Params]currentwindow=STRING|"1"fixedwindow=STRING|"1"keylayout=STRING|"0"keys=STRING|"^(+)"sendkind=STRING|"0"wincaption=STRING|"Notepad"[Actions\Action2]ActionID=STRING|"A_GENERAL_PAUSE"Enabled=INTEGER|-1Name=STRING|"Delay 200 ms"Params=FOLDER[Actions\Action2\Params]delay=STRING|"2"[Actions\Action3]ActionID=STRING|"A_GENERAL_SENDKEYS"Enabled=INTEGER|-1Name=STRING|"Send keys to active window"Params=FOLDER[Actions\Action3\Params]currentwindow=STRING|"1"fixedwindow=STRING|"1"keylayout=STRING|"0"keys=STRING|"xxxxxxxxx"sendkind=STRING|"0"wincaption=STRING|"Notepad"[Actions\Action4]ActionID=STRING|"A_GENERAL_SENDKEYS"Enabled=INTEGER|-1Name=STRING|"Send keys to active window"Params=FOLDER[Actions\Action4\Params]currentwindow=STRING|"1"fixedwindow=STRING|"1"keylayout=STRING|"67699718"keys=STRING|"+(2)"sendkind=STRING|"0"wincaption=STRING|"Notepad"[Actions\Action5]ActionID=STRING|"A_GENERAL_SENDKEYS"Enabled=INTEGER|-1Name=STRING|"Send keys to active window"Params=FOLDER[Actions\Action5\Params]currentwindow=STRING|"1"fixedwindow=STRING|"1"keylayout=STRING|"0"keys=STRING|"gmail.com"sendkind=STRING|"0"wincaption=STRING|"Notepad"[Actions\Action6]ActionID=STRING|"A_GENERAL_PAUSE"Enabled=INTEGER|-1Name=STRING|"Delay 200 ms"Params=FOLDER[Actions\Action6\Params]delay=STRING|"2"[Actions\Action7]ActionID=STRING|"A_GENERAL_SENDKEYS"Enabled=INTEGER|-1Name=STRING|"Send keys to active window"Params=FOLDER[Actions\Action7\Params]currentwindow=STRING|"1"fixedwindow=STRING|"1"keylayout=STRING|"0"keys=STRING|"^(+)"sendkind=STRING|"0"wincaption=STRING|"Notepad"xxxxxxxxx=in front of @Now it work, /me happy
