Issue While Using 7za.exe
feliciaIII
Post by feliciaIII »
Hello everybody, recently I tried to use the 7-Zip Command Line Application with RoboTask 3.2.1. It worked very well until I wanted to encrypt my archives with a variable value. My commandline looks like this (in my batch I use another variable for the -p Argument. I inserted the " because the password could contain spaces.)(C:\Programme\7-Zip\7za.exe) ApplicationParameters: "a "C:\Dokumente Und Einstellungen\Felix\Desktop\Hochladen\{FILENAME_O}.7z" -mx9 -mhe "{ORDNER}\{FILENAME_I}" -p"{FILENAME_I}""so far so good, the archives are being created. but when I try to open them again, I get an "wrong password" error. I tried to use this command without the " but got exactly the same error with every Archive. However, when setting -p"testeinszwei drei4.5x6"while leaving the rest unchanged, it works, even with encrypted filenames. Can anyone please give me suggestions? I need these variable Passphrases for every single file :-(thank you, Greets from Dresden, Germany - feliciaIII
Can you send me your task to oleg (at) robotask.com or publish it in the forum. Maybe you have some mistakes in the task.
What do variables FILENAME_O and FILENAME_I contain? You may chek this if you put "Show Message" before running 7-zip.
I've just wrote small example and test it. It's working.
See below:
CatID=INTEGER|1539658767
ExternalName=STRING|"Task753"
ID=INTEGER|1206726479
LocalVariables=STRING|"FILENAME_O,ORDNER,FILENAME_I"
Name=STRING|"Test 7-zip commang line"
Name=STRING|"Set variable ""FILENAME_O"" with value ""test"""
varname=STRING|"FILENAME_O"
varvalue=STRING|"test"
Name=STRING|"Set variable ""ORDNER"" with value ""c:\incoming"""
varname=STRING|"ORDNER"
varvalue=STRING|"c:\incoming"
Name=STRING|"Set variable ""FILENAME_I"" with value ""testeinszwei drei4.5x6"""
varname=STRING|"FILENAME_I"
varvalue=STRING|"testeinszwei drei4.5x6"
Name=STRING|"Run ""7z.exe a ""c:\dest\{FILENAME_O}.7z"" -mx9 -mhe ""{ORDNER}\{FILENAME_I}"" -p""{FILENAME_I}"""""
params=STRING|"a ""c:\dest\{FILENAME_O}.7z"" -mx9 -mhe ""{ORDNER}\{FILENAME_I}"" -p""{FILENAME_I}"""
program=STRING|"C:\Program Files\7-Zip\7z.exe"
runas=STRING|"0"
wait=STRING|"2"
feliciaIII
I finally found my mistake by trying the "showmessage" - as you suggested, it was made a few steps earlier. Now I corrected it and it works fine. thank you for your help. greets, felicia
