Vista 64-bit
verona
Vista 64-bit
Post by verona »
I have developed all of my RoboTask tasks in Vista 32-
bit, and I now have the need to verify that the work on
Vista 64-bit as well. However, I have run into a couple
problems.
* Any time I try to delete a file I get a warning that
"One ore more files can't be deleted" I've managed to
get around it by creating a batch file that takes in a
command line parameter of which file to delete, but I'd
much rather have the built-in action working.
* The "Wait for Process" action doesn't list as many
running processes as it did in Vista 32-bit. I can only
choose from VProTray.exe and RoboTask.exe; even
notepad.exe doesn't show up as an option (when it's
running, of course) I haven't figured out a way to get
around this one yet.
I'm running RoboTask 3.2.1 with patch #4 installed.
Vista 64-bit
1. What files do you try to delete? I tested this on vista - it's working. Maybe some files are locked by another process when task is working.
2. You are correct. RoboTask can detect too little processes under Vista. We'll investigate the problem and make necessary corrections.
