minimize to tray
DraBS
minimize to tray
Post by DraBS »
What do you think about "minimize to tray" action for windows?
minimize to tray
Most applications can't be minimized into system tray.
This feature must be implemented within application.
DraBS
minimize to tray
Post by DraBS »
Hm, there's an application called MKey (http://soft.softodrom.ru/ap/p4997.shtml => MKey 0.9.7.2). It has the option to set a key on your keyboard to minimize, when clicked, the currently active window (whichever it is) to the system tray:I don't know how they have achieved it but it has worked with any application I have tried so far.
minimize to tray
You may do this right now
See two sample tasks below. These tasks work with Notepad.exe
First task hides notepad and enables the second task
Second task unhides Notepad and disables itself.
Second task have "Tray icon" with notepad icon. So you see illusion that notepad has been minimized to tray.
First task:
CatID=INTEGER|1380072790
ExternalName=STRING|"Task761"
ID=INTEGER|1264386552
Name=STRING|"Hide Notepad to tray"
Name=STRING|"Hide window ""- Notepad"""
action=STRING|"5"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"1"
wincaption=STRING|"- Notepad"
winclass=STRING|"Notepad"
ActionID=STRING|"A_TASKS_ENABLE"
Name=STRING|"Enable Task ""UnHide Notepad from tray"""
taskid=STRING|"1537830626"
Second task:
ExternalName=STRING|"Task762"
ID=INTEGER|1537830626
Name=STRING|"UnHide Notepad from tray"
Name=STRING|"Unhide window ""- Notepad"""
action=STRING|"6"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"1"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"1"
ActionID=STRING|"A_TASKS_DISABLE"
Name=STRING|"Disable Task ""UnHide Notepad from tray"""
EventID=STRING|"E_GENERAL_TRAYICON"
filename=STRING|"{SYSTEMDIR}\notepad.exe"
iconindex=STRING|"0"
DraBS
minimize to tray
Post by DraBS »
Thanks!
