Pause/Break Key
gooser60
Pause/Break Key
Post by gooser60 »
Is there a way to simulate the Pause/Break key press or even better yet add it to the list of "canned" keystrokes available to use.
Pause/Break Key
Use the {BREAK} macro in your keystroke string
For example: ^({BREAK}) = Ctrl-Break
HubertNovakovic
Pause/Break Key
Post by HubertNovakovic »
I have tried it but it won't work for me. Do you think i
should try to use it via simple key stroke?
