How to copy the latest file in a folder:
Do you have a macro that can monitor a particular folder and move only the latest file in that folder ( modified or created last ) to another pre-determined folder.
Thank you.
See the example "[DEMO] Find the latest/newest modified file in a folder."
This task determines latest file in specified folder.
Next, you can copy this file or do some else.
Of course, you may copy and change this task for your purposes.
robotask846
Hi Oleg,
I had already tried that. I do not know how to modify this macro to achieve this purpose. Could you please help me if it is not much trouble.
I need to find the latest file in a folder and move it to a diferent folder.
Thank you.
Thank you.
See example below.
Pay attention to steps:
step #9. I turned off the "Without full path" parameter
step #19 Copy/Move file (added step)
CatID=INTEGER|1214054504
ExternalName=STRING|"Task752"
ID=INTEGER|729685853
Name=STRING|"[DEMO] Find the latest/newest modified file in a folder and copy it."
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Name=STRING|"Show ""This Demo finds the latest file in a specified folder."""
msg0=STRING|"This Demo finds the latest file in a specified folder."
message=STRING|"Current DateTime {CURRENT_DATETIME}"
message=STRING|"Latest DateTime {LATEST_DATETIME}"
[Actions\Action12\Params]
operator=STRING|"3"
type=STRING|"2"
value1=STRING|"{CURRENT_DATETIME}"
value2=STRING|"{LATEST_DATETIME}"
[Actions\Action13\Params]
message=STRING|"CURRENT_DATETIME {CURRENT_DATETIME} > LATEST_DATETIME {LATEST_DATETIME}"
[Actions\Action14]
Name=STRING|"Set variable ""LATEST_FILENAME"" with value ""{CURRENT_FILENAME}"""
[Actions\Action14\Params]
varname=STRING|"LATEST_FILENAME"
varvalue=STRING|"{CURRENT_FILENAME}"
[Actions\Action15]
Name=STRING|"Set variable ""LATEST_DATETIME"" with value ""{CURRENT_DATETIME}"""
[Actions\Action15\Params]
varname=STRING|"LATEST_DATETIME"
varvalue=STRING|"{CURRENT_DATETIME}"
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
Name=STRING|"Show ""Folder: {Current_Folder}"""
[Actions\Action18\Params]
msg0=STRING|"Folder: {Current_Folder}"
msg1=STRING|"Latest file: {LATEST_FILENAME}"
msg2=STRING|"Modified: {LATEST_DATETIME}"
msg4=STRING|"Press OK to copy it to ""c:\destination"" folder"
msgcount=STRING|"5"
[Actions\Action19]
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
[Actions\Action19\Params]
destdir=STRING|"C:\destination"
f_count=STRING|"1"
file0=STRING|"{LATEST_FILENAME}"
ifexists=STRING|"1"
move=STRING|"0"
subdir=STRING|"0"
Name=STRING|"Create variable ""LATEST_FILENAME"" with value ""Not Found"""
varvalue=STRING|"Not Found"
[Actions\Action20]
Name=STRING|"Remove variable ""CURRENT_FOLDER"""
[Actions\Action20\Params]
varname=STRING|"CURRENT_FOLDER"
[Actions\Action21]
Name=STRING|"Remove variable ""CURRENT_FILE"""
[Actions\Action21\Params]
varname=STRING|"CURRENT_FILE"
[Actions\Action22]
Name=STRING|"Remove variable ""LATEST_DATETIME"""
[Actions\Action22\Params]
[Actions\Action23]
Name=STRING|"Remove variable ""LATEST_FILENAME"""
[Actions\Action23\Params]
Name=STRING|"Create variable ""LATEST_DATETIME"" with value ""0"""
varvalue=STRING|"0"
caption=STRING|"Select Folder"
default=STRING|"None"
folder=STRING|"{TempDir}"
variable=STRING|"CURRENT_FOLDER"
value1=STRING|"{Current_Folder}"
value2=STRING|"None"
ActionID=STRING|"A_TASKS_STOP"
Name=STRING|"Stop Task ""Find the latest/newest modified file in a folder."""
taskid=STRING|"417887772"
Enabled=INTEGER|0
Name=STRING|"Set variable ""CURRENT_FOLDER"" with value ""{TempDir}"""
varvalue=STRING|"{TempDir}"
Name=STRING|"File Loop"
date1=STRING|"20040520"
date2=STRING|"20040520"
destvar=STRING|"CURRENT_FILENAME"
file0=STRING|"{Current_Folder}\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"CURRENT_DATETIME"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
operator=STRING|"3"
type=STRING|"2"
[Actions\Action14]
[Actions\Action15]
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
msgcount=STRING|"5"
[Actions\Action19]
f_count=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
subdir=STRING|"0"
[Actions\Action20]
[Actions\Action21]
[Actions\Action22]
[Actions\Action23]
varvalue=STRING|"0"
Enabled=INTEGER|0
subdirs=STRING|"1"
timesize=STRING|"1"
robotask846
Hi Oleg,
Thank you so much for your help.
Robotask is the single greatest applications I have found after extensive research. I am so happy with it. it is literally saving me time. It is great. The tech support is second to none.
Just to thank you Oleg.
