can robotask save files with custom name?
nick
Post by nick »
I have 100 html files that I want to save with the word
between <h1> and </h1> as name.
ex.
1. I have 0001.html with inside <h1>robotask help</h1>
2. result: robotask-help.html
ex2
1. I have 0002.html with inside <h1>robotask</h1>
2. result: robotask.html
gr.
Of course you can do this.
See the example below. It finds *.HTML files in c:\incoming folder and renames them by your rule.
CatID=INTEGER|1380072790
ExternalName=STRING|"Task744"
ID=INTEGER|615134226
Name=STRING|"Rename HTM files"
Action14=FOLDER
Name=STRING|"File Loop"
date1=STRING|"20081222"
date2=STRING|"20081222"
destvar=STRING|"C_HTM"
file0=STRING|"c:\incoming\*.html"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Rename File"
file0=STRING|"{c_htm}"
mask=STRING|"{newname}.*"
subdirs=STRING|"0"
Name=STRING|"Break"
[Actions\Action14]
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
file=STRING|"{c_htm}"
linecount=STRING|"0"
sourcetext=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"<h1>"
source=STRING|"{c_line}"
variable=STRING|"pos1"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{pos1}"
value2=STRING|"0"
Name=STRING|"Evaluate"
expression=STRING|"{pos1}+4"
variable=STRING|"POS1"
from=STRING|"1"
search=STRING|"</h1>"
variable=STRING|"pos2"
expression=STRING|"{pos2}-{pos1}"
variable=STRING|"LEN"
Name=STRING|"STR Extract"
amount=STRING|"{len}"
from=STRING|"{pos1}"
variable=STRING|"newname"
Enabled=INTEGER|0
Name=STRING|"Show ""{newName}"""
msg0=STRING|"{newName}"
nick
Post by nick »
Thanks Oleg, but I get this strange error:"The task contains UNKNOWN steps"The code whem imported:
What version do you use?
See below new edition of the task
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Internal basic script"
line00000=STRING|"Sub Main"
line00001=STRING|"Dim s As String"
line00002=STRING|"Dim Nm As String"
line00003=STRING|"Dim pos1 As Integer"
line00004=STRING|"Dim pos2 As Integer"
line00005=STRING|"Dim l As Integer"
line00007=STRING|"Nm = """""
line00008=STRING|"s = RoboTaskApp.ExpandText(""{c_line}"")"
line00009=STRING|"pos1 = InStr(s,""<h1>"")"
line00011=STRING|"If pos1>0 Then"
line00012=STRING|"     pos1 = pos1 + 4"
line00013=STRING|"     pos2 = InStr(s,""</h1>"")"
line00014=STRING|"     l = pos2 - pos1"
line00015=STRING|"     Nm = Right(Left(s,pos2-1), l)"
line00016=STRING|"End If"
line00018=STRING|"RoboTaskApp.SetUserVariable(""newname"",Nm )"
line00020=STRING|"End Sub"
linecount=STRING|"21"
source=STRING|"0"
operator=STRING|"8"
value1=STRING|"{newname}"
value2=STRING|"0"
Enabled=INTEGER|0
subdirs=STRING|"0"
Name=STRING|"Break"
nick
Post by nick »
Thank you, Oleg!
