If then
spotsphill
If then
Post by spotsphill »
I was wondering how I would have to code the task if I wanted the following:Step 1:  I open an Excel spreadsheet (I know how to do that)Step 2:  If cell A1 is blank, then Alt+F4Essentially, what I want to do is skip the spreadsheet document if it is blank.How do I set up Step 2?  Is it using if/then?  Please help. Thanks!- Phill
If then
For example you may get the content of cell A1 into the clipboard and analyze the clipboard content
spotsphill
If then
Ok, so if I copy the contents of the cell, how do I
analyze it?
I want to delete the Excel file if it contains a blank
A1 field.
Help! Thanks
If then
how do I analyze it?
For example you may compare it with something.
In your case you have to trim EOL symbols (see "STR Trim") and compare with empty string.
[qute]I want to delete the Excel file if it contains a blank A1 field.
[/quote]
First you must close the file
