Rename Folders
kivanck
Rename Folders
Post by kivanck »
Hi ! I couldn't figure out how to do this but I guess that must be easy to do! All I want to do is to rename all subfolders in a specific folder by adding [ before the folder name and ] after the folder name.I mean "Folder 1" should be "[Folder 1]" after the task. Can you guys help me on this? Thanks a lot ...KK
Rename Folders
It's possible. See task below.
save the text of the task into file and use menu "Task | Import" in order to import into RoboTask
The sorting of the list is necessary (between the loops), because we need to rename the folders from bottom of folder tree to top.
First loop retrieves the folder tree and second loop renames folders from bottom.
CatID=INTEGER|1380072790
ExternalName=STRING|"Task742"
ID=INTEGER|340972587
Name=STRING|"rename subfolders"
ToLog=INTEGER|0
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"c:\incoming\list.txt"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"File Loop"
date1=STRING|"20081211"
date2=STRING|"20081211"
destvar=STRING|"C_FOLDER"
file0=STRING|"C:\incoming\*.*"
searchkind=STRING|"1"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Create text file c:\incoming\list.txt"
fileexists=STRING|"1"
filname=STRING|"c:\incoming\list.txt"
line0=STRING|"{c_folder}"
Name=STRING|"Run ""cmd.exe /c sort /r c:\incoming\list.txt > c:\incoming\slist.txt"""
params=STRING|"/c sort /r c:\incoming\list.txt > c:\incoming\slist.txt"
program=STRING|"cmd.exe"
runas=STRING|"0"
wait=STRING|"2"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
file=STRING|"C:\incoming\slist.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
ActionID=STRING|"A_FOLDER_RENAME"
Name=STRING|"Rename Folder ""{c_line}"""
folder=STRING|"{c_line}"
newfolder=STRING|"{ExtractFilePath({c_line})}\[{ExtractFileName({c_line})}]"
