Send Break Key
jasv
Send Break Key
Post by jasv »
I want to control Remote desktop via a robotask macro. Remote desktop requires that you can send the <alt><ctrl><break>. I looked in help and found ctrl and alt but I can't find how to send a break key stroke. Is there a way?
Send Break Key
Just send this combination: ^(%({break}))
Unfortunately the key {BREAK} is not documented, but it's working. I've just tested this.
We'll correct help file and action editor in future.
