How to move files using robotask
techgru
Post by techgru »
Hi Friends,I just came across this amazing software and I have one repetetive task everyday, so i need some help. My question isI have one folder say "C:\suff" which might contain bunch of zip files, exe files,pdf files. Also there are Test1.jar,Test2.jar, Test3.jar etc. Now what i want to do is take the name of the first file sa Test1.jar and create a folder of these name in "D:\backup\Test1" and take only Test1.jar,Test2.jar,Test3.jar and put it in destination folder. Same way for other files it creates separate folder based on file name and put similar files in that folder. Is it possible using Robotask? If yes then please help me.Thanks you very much friends
What criteria of similarity? Maybe the first three or four symbols?
