Error notification
fruitloopy
Error notification
Post by fruitloopy »
Is it possible that if a task fails to complete and produces an error it can perform an action?
I cant see how I can acheive this using the tools available.
Error notification
Go to "Advanced" tab of task editor.
Set the parameter "If error occurred" to "continue execution"
Now you can use {IsError} system variable.
Put after critical step the following steps
if {IsError} = true then
   do something
end if
