Clipboard issue
rtl2710
Clipboard issue
Post by rtl2710 »
I'm trying to copy a text from pdf file to clipboard,
unbreak lines, and copy the text back to clipboard.
I'm using AutoUnbreak to remove line breaks, and
robotask to copy the selected text, paste into
AutoUnbreak, press 3 buttons to get my text without
lines copied to clipboard, and exiting the program.
The script I'm using does open AutoUnbreak, but nothing
happens after that.
Does anyone know what I'm doing wrong? I can post the
script if requested.
Clipboard issue
See the example below. It's working.
Save the text of the task to file and use menu Task | Import in order to import into RoboTask. Don't forget to enable it.
This example works so: select necessary part of PDF and press Ctrl-Alt-P
CatID=INTEGER|1961495446
ExternalName=STRING|"Task22"
ID=INTEGER|1176102695
Name=STRING|"Copy from PDF"
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Set variable ""TXT"" with value """""
varname=STRING|"TXT"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
line0=STRING|"{ClipBoardContent}"
sourcetext=STRING|"1"
Name=STRING|"Set variable ""TXT"" with value ""{TXT} {c_line}"""
varvalue=STRING|"{TXT} {c_line}"
Name=STRING|"Show ""{TXT}"""
msg0=STRING|"{TXT}"
hotkey=STRING|"49232"
