Loop an task
kanuddel
Loop an task
Post by kanuddel »
is it possible, to loop an complete task?im sure it is anyhow, but i haven't find this function jet. can anybody help me please?thanks
Loop an task
Hm...
Create the task, which does the following:
Simple loop
   Start task //another task with waiting
end loop
You may use "While loop" instead of "Simple loop"
Also you can simply attach to the task "Cyclic" triggering event and start the task automativally each 5 sec (for example)
