HTML file contents into body e-mail
Gekseppe
Post by Gekseppe »
Hi;
I would need some help to create a task with the following actions:
1. copy the contents of a HTML file;
2. paste the contents of the HTML file into the body e-mail.
Many thanks !
There is {TextFile()} system variable for this purpose.
Just put into message body approx the following:
{TextFile(c:\tempfolder\MyFile.html)}
HTML file is the text file, therefore you can use {TextFile()} variable.
You have to specify the full file name of your HTML as parameter.
Gekseppe
Post by Gekseppe »
Thanks !
