loop with variables
sanremy
loop with variables
Post by sanremy »
ROTA does all my work nicely, but i must entered the 4 variables for each loop & in fact, only one variable changes. How can i program ROTA, to move the value of V3 to V4 , value of V2 to V3, value of V1 to V2 (then i enter value of V1) , at the beginning of each loop ?
i have tried to do this, using the clipboard as a buffer, but the value comes back alterated ( put V3 in CLIP, get CLIP in V4, if then V3 = V4 gives NO ! )
thanx
loop with variables
See the task below.
This task input new value and assign it to VAR1. Existing values moves so:
Var3 -> Var4
Var2 -> Var3
Var1 -> Var2
New value ->Var1
If you enter 0 then the task will finished.
CatID=INTEGER|700197831
ExternalName=STRING|"Task636"
ID=INTEGER|2118081295
Name=STRING|"Shift the values between variables"
Name=STRING|"Set variable ""VAR1"" with value ""1"""
varname=STRING|"VAR1"
varvalue=STRING|"1"
Name=STRING|"Set variable ""VAR3"" with value ""{VAR2}"""
varname=STRING|"VAR3"
varvalue=STRING|"{VAR2}"
Name=STRING|"Set variable ""VAR2"" with value ""{VAR1}"""
varname=STRING|"VAR2"
varvalue=STRING|"{VAR1}"
Name=STRING|"Set variable ""VAR1"" with value ""{BUF}"""
[Actions\Action12\Params]
varvalue=STRING|"{BUF}"
Name=STRING|"Set variable ""VAR2"" with value ""2"""
varvalue=STRING|"2"
Name=STRING|"Set variable ""VAR3"" with value ""3"""
varvalue=STRING|"3"
Name=STRING|"Set variable ""VAR4"" with value ""4"""
varname=STRING|"VAR4"
varvalue=STRING|"4"
Name=STRING|"Set variable ""BUF"" with value ""-1"""
varname=STRING|"BUF"
varvalue=STRING|"-1"
Name=STRING|"While loop"
operator=STRING|"1"
value1=STRING|"{buf}"
value2=STRING|"0"
Name=STRING|"Show ""var1={var1}"""
msg0=STRING|"var1={var1}"
msg1=STRING|"var2={var2}"
msg2=STRING|"var3={var3}"
msg3=STRING|"var4={var4}"
msgcount=STRING|"4"
Name=STRING|"Input Box"
default=STRING|"0"
prompt=STRING|"Input some value. 0 to exit"
variable=STRING|"BUF"
Name=STRING|"Set variable ""VAR4"" with value ""{VAR3}"""
varvalue=STRING|"{VAR3}"
