Robotask will not click
johnrouge
Post by johnrouge »
It seems every thing in Robotask is working fine, except for when Robotask is supposed to run a mouse click, it forgets to.  It will run the mouse "moves" fine, but it won't click.  It says in the log it ran the click, but it doesn't.  Any ideas folks? Thanks in advance.John Rouge
Do you use this in locked console?
System ignores mouse and keyboard actions in locked console. This is property of Windows.
johnrouge
Post by johnrouge »
Locked console?  How do I check if it's in locked console?
johnrouge
Post by johnrouge »
I'm not familiar with locked console.  And if it turns out I'm in locked console (which I probably am), then how do I unlock it?  Thanks in advance.JR
johnrouge
Post by johnrouge »
Ok, so I found out what was wrong.  It turns out Comodo Firewall + Defense was not allowing Robotask to access the mouse or keyboard.  Problem solved.
