Add Date & Time in txt-file
Agda Drift
Post by Agda Drift »
Is it possible to add date and time in the textfile before the the text you define in the task "Write to text file". I want to create i simple logfile from the task.
Yes, of course. Just insert {DateTime} string before your text line.
You can find more variables here: menu Options -> Variables
Also see a simple example below:
CatID=INTEGER|700197831
ExternalName=STRING|"Task613"
ID=INTEGER|1197903318
Name=STRING|"Simple Log File"
Name=STRING|"Create text file c:\simpleLog.txt"
fileexists=STRING|"1"
filname=STRING|"c:\simpleLog.txt"
line0=STRING|"{DateTime}; My text "
