How to batch upload local -> remote?
thales
Post by thales »
Any tips? Currently I'm using mput to batch upload from a local folder to a remote folder. Robotask uses 100% CPU when waiting for mput to finish so I'm hoping that Robotask can batch upload.
thanks
See sample task below. Save this text to <Any_name>.tsk file and use "Task|Import" menu to import this task into RoboTask.
;begin task
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1664541561
ExternalName=STRING|"Task23"
ID=INTEGER|1451030729
Name=STRING|"Batch FTP Upload"
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"0"
port=STRING|"21"
username=STRING|"anonymous"
ActionID=STRING|"A_FTP_TRANSFERTYPE"
Name=STRING|"FTP Transfer Type"
binary=STRING|"1"
Name=STRING|"Change Folder (C:\Temp\src)"
folder=STRING|"C:\Temp\src"
Name=STRING|"Text Loop"
destvar=STRING|"FILETOUPLOAD"
line0=STRING|"HelpDemo.exe"
line1=STRING|"HelpDelphi.cnt"
line10=STRING|"HelpDemo.res"
line11=STRING|"HelpDemo.rtf"
line12=STRING|"Readme.txt"
line13=STRING|"helpd3_5.zip"
line14=STRING|"HelpDemo.zip"
line2=STRING|"HelpDemo.cnt"
line3=STRING|"uhdmain.dfm"
line4=STRING|"HelpDemo.dpr"
line5=STRING|"HelpDemo.GID"
line6=STRING|"HELPDELPHI.HLP"
line7=STRING|"HELPDEMO.HLP"
line8=STRING|"HelpDemo.hpj"
line9=STRING|"uhdmain.pas"
linecount=STRING|"15"
sourcetext=STRING|"1"
ActionID=STRING|"A_FTP_UPLOAD"
Name=STRING|"FTP Upload"
file=STRING|"{FILETOUPLOAD}"
folder=STRING|"\upload"
ActionID=STRING|"A_FTP_LOGOFF"
Name=STRING|"FTP Log Off"
;end task
