Create variable for full path of a file
David.Marsh
Post by David.Marsh »
I am using RoboTask Lite and want to know how I can place the full path of a file into a variable by using the File Monitor.My example is I want to monitor a folder for a file but the name of the file that is copied into the folder is unknown at the time of running the task so I want to monitor a folder and store the full path of the new file into a variable so that I can then create a text file that will contain some information along with the full path to the new file.Is this possible with RoboTask Lite?
You may retrieve the content of text file by using variable {TextFile(file_name)}. Specify the file name as parameter.
In order to assign this to variable use "Set Variable" action.
