Who decides FTP transfer types?
bubbles
Post by bubbles »
Great that this version allows FTP transfers in lower case ... BUT I am having big problems with some file types... big problems...
I have just been syncing 20+ websites and some of the files on the server are not working now.
My usual FTP program asks if I wabt binary or ascii for unknown file types, but Robotask does not ask me, how does it know, and how can I change any settings already set.
The problem files are mainly PNG graphic files and some non extension compiled cgi files and non extension JS files ...
Thanks, for any help, T
Probably this is known bug in "FTP Synchronization" action.
Try to use the corrected version of this plugin.
How to install:
1. Stop RoboTask
2. Unpack plugin over old. Usually it is in "C:\Program Files\RoboTask\Plugins\FTP\" folder
3. Start RoboTask again.
