Can I do this or is this a suggestion?
bubbles
Post by bubbles »
Hi, I have lots of task in lots of folders and in each folder, I would really like to be able to chain ALL of the tasks to run in the order they appear in the folder, without having to create another task to "fire" each task, is there an easy way to  just chain or fire all the tasks, or is this a  good idea for a future version of Robotask?
Do you want to run selected tasks sequentially? This future is already implemented in next version (coming soon). But now I recommend you to create separated task which runs specified tasks in necessary sequence. Also, if you specify "Wait for finish" parameter then RoboTask will run next task after previous will done.
