Selecting multi files to zip
sharkb8
Post by sharkb8 »
How would you script RT to select all of the same files, with the same extension ,to zip up ? I can only select one file to zip at this point.
No problem. See this example.
You have to select the source folder and input the mask of files you want to pack.
In order to pack group of files you have to specify one or more masks in "File to zip" parameter of the action (one mask on the line).
sharkb8
Post by sharkb8 »
Is that file written in that basic language? If all goes well, I will purchase the program for personal and work as soon as I am more confident using it. I appreciate your help oleg.
This file is a task of RoboTask.
Just save the task into some file, and use menu Task | Import to import into RoboTask
Also you can find more examples here.
This task doesn't contain "basic script" action
sharkb8
Post by sharkb8 »
Wow! you are the man! Expect me to purchase the program soon. If i could shake your hand i would.....
