Export
bubbles
Export
Post by bubbles »
When I choose export, from the file meu, I can only export the task(s) within the current folder.... Is there a way to export ALL tasks and ALL folders or even just ALL tasks?
Thanks, T
Export
Yes you can.
Just hide the folders tree (menu Options | View tree or click on "View tree" button on toolbar)
Next you may select all tasks and export them into specified folder.
bubbles
Export
Post by bubbles »
OK Oleg ... thanks for this .. I shall try it and see if it works for me
