Insert input field
egoiste
Insert input field
Post by egoiste »
Hi,I have RoboTask 2.6 and it saves me a lot of time, its one of the most useful programs I have.I have a task that I want to repeat x number of times. For now, I have created a simple loop where I enter the number of repetitions. Its OK, but it would be easier if I could exchange the simple loop for an input box where I would enter the number of times the task should repeat and the task would then repeat according to the entered value. How can I do this? I have already tried, but no luck, I must be doing something wrong.Thanks, Miro
Insert input field
See this example
(save to file and use menu Task | Import in order to import to RoboTask)
Also you can find more examples here
egoiste
Insert input field
Post by egoiste »
So simple, entering the variable as the To value... :-)Thank you Oleg, it works like a charm. Now I just sit, watch and become lazy :-)Miro
