Problem with "Synchronize Folders"
Thomas N.
Post by Thomas N. »
Hi there,I'm new in using RoboTask, so the problem I have to solve, is  maybe only trivial.I generated a task, containing of a trigger event, named "FileMonitor", so that I get a trigger, each time something changes in the folders, I monitor. If that event becomes true, I use the function "Synchronize Folders" to make a consistent replica of the folder to a destination folder on another device. You see, a simple delta backup, which is triggered by data changes in the source folder.My problem: I didn't found a way to copy hidden folders and hidden files. Therefore it doesn't matter if the hidden objects are switched to  visible in the OS or not. There is no flag, that would allow me to change this behaviour of RoboTask.Am I'm making a mistake? Maybe someone is able to help me, so that I'm able to sync hidden files and folders, too.I hope my Englisch wasn't too worse, as I've had no practice for years, since I learned the language in school.Thanks a lot for helping me.Greetings,Thomas
Thank you for the report. This lack will be removed in next release.
