Strange FTP Sync issue
tdawebdesign
Post by tdawebdesign »
Hi All,
I have this very strange issue where i try to do a ftp sync of a basic
folder with 2 files in it.  It takes about an 1 hour to process the
task but nevery sycs and returns this error over and over aftwards
(about 25 times).  See below
E: 1/30/2008 1:27:22 PM: FtpCreateDirectory fails with message: The connection with the server was reset<CR><LF>
E: 1/30/2008 1:27:22 PM: FtpGetCurrentDirectory fails with message: The connection with the server was reset<CR><LF>
The FTP login works fine and i can upload and download files via a task
but it just wont sync.  What going wrong as i have the same setup on
another server and it works like a charm.
YOur help is greatly appreciated.
Tim
It takes about an 1 hour to process the task ...
Why so long???
How many files are in destination folder?
What version of RoboTask do you use?
tdawebdesign
im using the latest version but on trial at the moment for this server,   i have no idea why it doesnt work.  It doesnt give me an error straight away it hangs for an hour and then quits the task and states
E: 1/30/2008 1:27:22 PM: FtpCreateDirectory fails with message: The connection with the server was reset<CR><LF>It just wont ftp sync, all other ftp functions work fine.....  Its bizare because i have the same setup on another server and works fine and i installed robotask on anther machine and it synced fine to the desination, so its definately not an FTP issue.Tim
tdawebdesign
Ok its all good.  For FTP Sync on this server i must enable PASVThanksTim
