Question Dialogue Not Displayed
isense
Post by isense »
I am trying to build a task with a question dialogue.  I have set this to select YES if no action for 15 secs.
When I run the task I get a new program in the task bar for it, but the dialogue is not diplayed anywhere on screen.  After 15 secs the task bar entry disappears.
I am running on Vista Ultimate on a system with 3 monitors
Any ideas?
isense
Post by isense »
I think I've solved the problem.  It's assocaited with running 3 monitors.  I have 2 monitors on one NVIDIA 8800GTX card and a third on a 8500GT card.
If I disable the 3rd monitor, the dialogue works OK
We'll investigate this problem. Thank you for the report.
