Apply a task to a selected file
steph@vds
Post by steph@vds »
Hi,Is there a way to apply a task (with a hot key triggering) to a file just selected by the user ?I'm trying to store the path of a file in a variable.Steph@vds.
Do you want to use an external task? I.e. any task file which is in any place as you want?
steph@vds
Post by steph@vds »
Hi Oleg,Excuse me but I don't really understand your answer.All my tasks are in the tasks folder of my installed Robotask.If I need another way of executing the task, it's ok for me but I'd prefer to use the normal way.
