Retain ’Date Modified" when copied
Prem
Post by Prem »
Is it possible in Robotask to create a task that moves a file without the file properties being changed? I need files to keep the original Date Modified and, if possible, the same 'Modified By'.
Thanks
Prem
Each file have 3 parameters of time:
- Modification time
- Creation time
- Last access time
While copying RoboTask uses system function of copying of files. This function changes only "Last access time" parameters. "Creation time" and "modification time" remain the same.
