Default Printer
julianhansen
Default Printer
Post by julianhansen »
I note RoboTask can print to not the default printer.
Would it be possible for RoboTask to detect when you change networks and change the default printer depending on the network you are connected too?
Default Printer
RoboTask use system shell function to print any document by using default application. This function allows to print document onto default printer only.
Lipe
Default Printer
Post by Lipe »
Change default printer - run command
rundll32 printui.dll,PrintUIEntry /y /n "printer_name"
See you http://support.microsoft.com/kb/314486/en-us
