FTP delete file not working?
whiskey3
Post by whiskey3 »
It keeps saying that "no such file exists" even though the file does exist on my server? Why won't it delete it? Spelling is correct.......
Some FTP servers has case-sensitive names of files
whiskey3
Post by whiskey3 »
I know about that and it's spelled correctly......I even tried a file called "welcome.htm" and it still didn't remove it. The FTP delete does not work.......what's up? I tried the upload and that works but my delete is not working??? Any suggestions?
Thanks.
whiskey3
Post by whiskey3 »
Can someone please try it.....I'm telling you it doesn't work on my end. It logged in and moved a file bit it won't delete it.......I'm going to move over to Automate this is a hassle.
Try to use "FTP Change Folder" action before file deletion
whiskey3
Post by whiskey3 »
It still doesn't work. Why would I want to change a folder anyways?
Thanks.
whiskey3
Post by whiskey3 »
I got it to work with the change folder command now. Thanks.
Can you please explain what hat command does and why it wouldn't work without it?
