Folder for TrayIcon menu
Jabberwock
I have some tasks which I would use from time to time... I do not want to sacrifice a hotkey or a tray icon, still accessing them from the main RoboTask window is not that convenient either...Maybe the RoboTask tree could contain a special folder, which structure would reflect a menu accesible from the RoboTask tray?For example:TrayMenu|Rarely used |Clean up (task in that folder)Then one would click the RoboTask tray icon, select from the menu "Rarely used", then "Clean up" and the "Clean up" task would be run...
