search for files
degoup
search for files
Post by degoup »
I test version 2.5.1
I want to create a list, but i need two time the variable "name"
Résult : <option value="releve_consigne/B_041_DIEPPE.pdf">XX</option>
I want : <option value="releve_consigne/B_041_DIEPPE.pdf">B_041_DIEPPE.pdf</option>
Is it possible ?
Thanks.
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|1902005443
Name=STRING|"test"
Name=STRING|"Create File List (C:\titi.txt)"
After=STRING|"0"
aftercount=STRING|"1"
AfterLine=STRING|"1"
AfterLineText=STRING|""">xx</option>"
Before=STRING|"0"
beforecount=STRING|"1"
BeforeLine=STRING|"1"
BeforeLineText=STRING|"<option value=""releve_consigne/"
date1=STRING|"20070820"
date2=STRING|"20070820"
destfile=STRING|"C:\titi.txt"
file0=STRING|"\\releve_consigne\B_*.pdf"
filecount=STRING|"2"
searchkind=STRING|"0"
subdirs=STRING|"0"
WithoutPath=STRING|"1"
search for files
Yes of course you can do this.
But I think that you have to use file loop. Look at the example below. If you have any questions, feel free to ask me.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1947094105
ExternalName=STRING|"Task515"
ID=INTEGER|255203920
Name=STRING|"test with loop"
Name=STRING|"Set variable ""MY_TEXT"" with value """""
varname=STRING|"MY_TEXT"
Name=STRING|"File Loop"
date1=STRING|"20070821"
date2=STRING|"20070821"
destvar=STRING|"CURRENT_FILE"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""MY_TEXT"" with value ""{my_text}<option value=""releve_consigne/{current_file}"">{current_file} </option>{Eol}"""
varvalue=STRING|"{my_text}<option value=""releve_consigne/{current_file}"">{current_file} </option>{Eol}"
Name=STRING|"Create text file c:\titi.txt"
fileexists=STRING|"0"
filname=STRING|"c:\titi.txt"
line0=STRING|"{my_text}"
degoup
search for files
Post by degoup »
It's ok... But i change a command ligne.
Name=STRING|"Set variable ""MY_TEXT"" with value ""{my_text}<option value=""releve_consigne/{current_file}"">{current_file}&a mp;l t;/option>{Eol}"""
I just cut }&l t; and remplace by <
Thanks
search for files
degoup wrote:It's ok... But i change a command ligne.
Oh, yes. Message editor of the forum breaks the text sometimes.
