reading programm exit codes
aatjan
Post by aatjan »
Hi, is it possible to read a programm return - exit code into a variable and act on that ?
Thanks
Yes, of course. Look at the "Run Program/Open document" action. If you use "Wait until the application exits" wait option, you can catch exit code and assign it onto some user variable.
