Error opening a Scheduler
David.Marsh
Post by David.Marsh »
I have upgraded to Windows Vista Enterprise and whenever I try to access a Scheduler in Triggering Events I get the following error:"An error has occured. Delete this Event."This occurs for existing and new RoboTasks that I create.This means I can no longer update the schedules. I have to remove the existing Scheduler and create it again just to make a change.The schedule still runs, but I can't access it.Can you please look into fixing this bug.Thanks.
Yes, there was such problem. We already fixed this bug and you can download newest version from our site http://www.robotask.com/downloads/RobotaskSetup.exe
David.Marsh
Very strange. I had already installed version 2.5.1 but when I compared it against the latest version on your website there was a 4kb difference in file sizes but both had the same version number. The file must of been updated after I got the original 2.5.1 version.I installed the latest version and the problem is resolved.Thanks.
It is another build in our site now.
