Protect Data Option
dcocke
Protect Data Option
Post by dcocke »
RoboTask has an option under the Tools Menu to 'Protect Data' with a password.
I occassionally forget to set this password after making changes.  I would like to write a script that periodically checks to see if the data protection is on and alert me via email if it is not.
Do you know of a way I can test to see if it is set?  Registry entry or a property using SAX basic?
Thanks,
David
Protect Data Option
I'm afraid that there is no reliable way to check this.
RoboTask writes these settings into registry, but only while exiting.
