delete by date
jeffthebat
delete by date
Post by jeffthebat »
I am writing a task to monitor files over 14 days old and delete them. I see several ways to do this, but I was wondering what the simplest way would be?
I have the trigger set up, should I use the "search for files " with a date filter?
delete by date
It depends of your wish.
"Search for files" and "File loop" actions have the same date filter. Thus you can select files which you want.
For example, I use File Loop action in order to delete old files in temporary folder. This is more comfortable for me.
