Exclude dates?
gooser60
Exclude dates?
Post by gooser60 »
Essentially, I would like to be able to schedule certain processes to run only on days the US Stock Markets are open.  I wouldn't expect the software to know the holidays necessarily, but giving me the ability to input the days I do not want the process to run would be nice.   I assume, I could create and array of the weekeday holidays the process shouldn't be run on and put an additional check before the program is executed to determine if it's a holiday, based on my array of weekday holiday dates?
Exclude dates?
Excuse me, I don't understand your question. Do you want to know how to make this check?
gooser60
Exclude dates?
Post by gooser60 »
I was more saying that it would be nice when setting up a schedule task to say have the ability to exclude certain dates.
If it is possible for you to quickly show me how to do this that would be great.
Re: Exclude dates?
See this example (see below):
You can create the list of holidays and simply stop the task if today is holiday date.
ExternalName=STRING|"Task88"
ID=INTEGER|1750422847
Name=STRING|"exclude holidays"
Name=STRING|"Create local variable ""HOLIDAYS"" with value ""01-01-2016{EOL}08-01-2016{EOL}24-08-2016"""
varname=STRING|"HOLIDAYS"
varvalue=STRING|"01-01-2016{EOL}08-01-2016{EOL}24-08-2016"
operator=STRING|"6"
value1=STRING|"{DateTimeToFormat({Date},dd-mm-yyyy)}"
value2=STRING|"{holidays}"
Name=STRING|"Show ""Today is holiday. Exiting."""
msg0=STRING|"Today is holiday. Exiting."
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"Place your actions here"
position=STRING|"3"
title=STRING|"Normal working"
width=STRING|"330"
elwayfan446
Re: Exclude dates?
Post by elwayfan446 »
Can this task be used by other tasks without having to insert this logic into every task that is scheduled? I was able to import this task as instructed but it appears to be on its own. I will have many tasks that are scheduled and would like to be able to stop running them all if it falls on a holiday or weekend.
Thanks!
Re: Exclude dates?
You can save holiday dates in the separate text file and use it in your task.
One date per line.
system variable TextFile can read the text file
Use the expression {TextFile(file_name)}
